SOLD: Jasmine LP2.0MK II Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 905 times.
narkleptic
« on: 25 Mar 2017, 02:00 am »
SOLD
Rarely seen on the used market. MM/MC phono stage. Dual chassis design with separate power supply. Knob-adjustable MC load impedance--no DIP switches to mess with.This is a solid, exceptionally well-designed unit with superb build quality. Single-ended, class-A topology, with hand-matched J-FETs and high-quality parts all-around.
Specs, copied from the website:
Output Level : 10V (Max)
Input Impedance: MM = 47K ohm MC = 50/100/250/1K ohm selectable
S/N: MM > 90dB , MC > 85dB
THD: < 0.01 ( 20Hz to 20KHz )
Input Capacitance: 100PF
Gain @1KHz: MM = 55dB; MC = 70dB
Overall condition is good. There is a small mark on the bottom right faceplate glass on the power supply unit and another on the bottom left faceplate glass of the phono stage. It looks like some of the paint has come off. The marks are there, but you have to look pretty hard. I have had this unit for two years and didn't the marks until I took these pics.
Original box and foam for safe, easy shipping. Price includes shipping in CONUS. Local pickup available from Los Angeles.
$400
« Last Edit: 17 Apr 2017, 08:38 pm by narkleptic »
cal3713
Re: FS: Jasmine LP2.0MK II Phono Preamp
« Reply #1 on: 29 Mar 2017, 07:46 pm »
I had one of these until I sold all of my vinyl equipment... it completely outclassed the PS Audio GCPH I tested it against.  Would buy again if I decided to get back into analog.
narkleptic
« Reply #2 on: 6 Apr 2017, 05:03 am »
bump for lower price.
