0 Members and 1 Guest are viewing this topic. Read 5429 times.
"You should try reversing the polarity of your woofer connections (while leaving the main panel connections the same.) Since you've altered the roll-off slopes from stock, the Magnepan relative wiring polarity between woofer and main-panel is no longer correct...theoretically. This polarity reversal will correct the panel integration to properly match the LR4 slopes your Crown amplifier has"
Audio signal is AC,polarity of driver is neutral with ac signal,sorry but don't have experience with crown amps,even in multi-driver speakers polarity doesn't matter,mho
You're an entertaining fellow though. Dave.
A start on understanding phase shift in crossovers. Read more about it!Here's the link: http://sound.whsites.net/ptd.htmScotty
Hi ScottyI was reffering to single driver polarity on ac and driver freq domain
