0 Members and 1 Guest are viewing this topic. Read 28289 times.
That's a really interesting point Russell. I don't see the relevance of cone motion feedback in an open system. Probably why SL relies on ASP/DSP to accomplish his goal.
Servo feedback doesn't make sense in any ported enclosure either, as far as I can see—only sealed.
Well I can't say whether it makes any sense or not. But I know that OB servo controlled bass is the best I have heard in my room, from either a subwoofer or full range speaker.Shakey
Go and listen to the Servo OB system used in the GR Research designs (Super V, Super 7, LS whatever). I was a skeptic too, it made no sense to me. But that's the cool thing about direct experience - it often contravenes your expectations. I'll leave it to others to argue about "why" it works. I just know that I've heard some pretty crazy ass bass systems (ported, sealed, box, OB, Infinite Baffle, transmission line, passive radiator, swarms, servo sealed, etc...). None of them sound as good as this OB Servo implementation. It doesn't happen very often in this hobby, but on rare occasions you run across something that is just flat out better than everything else. This is one of those instances.
Why not?The objective is simply to try and make the cone accurately reflect the drive/input signal, yes?This correction would not be invalid regardless of the baffling scheme the woofer is operating in.I would stipulate it probably makes more sense in a closed-box (especially a small box) scenario since you have placed mechanical constrictions on the driver movements.Dave.
I believe you and absolutely love the OB bass of my Spatials but I'm curious why nobody from the industry has made a finished stand alone OB servo sub for those of us non-DIY'ers?David
I wonder why more speaker manufacturers don't use it as the bottom half of a speaker system. It works phenomenally well on my Super 7's.Especially things like Maggies or other planar speakers would benefit enormously from this type of bass foundation.
This is the closest I've seen to what you're referring to: http://www.spatialaudio.us/lumina These speakers appear to use the Rhythmik Audio OB servo drivers and amps. Check out the prices and the weight, though.
Highly entertaining how the crew here steered this thread from Linkwitz on OB to advertising for GR Research servo woofers. Dave.
Back to the original quote: "It is difficult to screw up an open baffle speaker design to where it sounds worse than your typical box speaker." - Siegfried Linkwitz.Proof that even smart people exaggerate for emphasis- or perhaps it's taken out of context. If you read this to mean that some diy OB drivers thrown into a baffle will be better than a cheaply but professionally designed box speaker, I don't agree.
I think he takes professional designer as a default assumption.
