Panasonic sa-xr70
0 Members and 1 Guest are viewing this topic. Read 5154 times.
gongos
Panasonic sa-xr70
« on: 29 Nov 2004, 07:09 am »
Does anyone know why onecall.com is the only place selling it?
tex-amp
Panasonic sa-xr70
« Reply #1 on: 29 Nov 2004, 03:41 pm »
The explanation I read somewhere is Panasonic is only allowing dealers above a certain level carry the XR70.  That is why J & R doesn't have it.
gongos
Panasonic sa-xr70
« Reply #2 on: 29 Nov 2004, 09:11 pm »
And there's only one retailer above that level?
jackman
Panasonic sa-xr70
« Reply #3 on: 29 Nov 2004, 10:03 pm »
I think it's something like $360 delivered from onecall.  That's a pretty good price.  It's not much more than the SR45.  It has nicer binding posts!  The 45 has a fan that is very quiet.  It doesn't look like the 70 has a fan.  This could be trouble because my fan is on quite a bit.
J
Neild
Panasonic sa-xr70
« Reply #4 on: 27 Dec 2004, 09:21 am »
I have xr45 & 50.  The 45 fan does cut in but the unit stays really cool.  xr50 on the other hand with no fan warms up like conventional fanless amps.  I think Panasonic determined that the receiver could live with the added heat and that a cooling fan wasn't needed.
pjchappy
Panasonic sa-xr70
« Reply #5 on: 27 Dec 2004, 08:46 pm »
Does the 70 have binding posts?
p
futuresng
New XR 70
« Reply #6 on: 6 Jan 2005, 12:19 am »
Hi folks....im a newbie that just bougtht the panny xr70 and the panny dvd s97s.  I am having it delivered by tomorrow.  any suggestions on set up? ie. cable set ups to the binding posts?, adjuststments?, settings?, break in time ?, etc.
I will be hooking up to my new onix rockets 5.1 system from av123.com.
thanks a bunch....not many owners of the 70's or at least not much chatter on the boards anyways.
JnC
Re: New XR 70
« Reply #7 on: 6 Jan 2005, 01:22 am »
Quote from: futuresng
Try here:
http://www.avsforum.com/avs-vb/forumdisplay.php?s=&forumid=90
AphileEarlyAdopter
Panasonic sa-xr70
« Reply #8 on: 6 Jan 2005, 09:16 pm »
Quote from: Neild
Neil,
Could you give us your take on the sonic differences between the XR45 and XR50, please ?
futuresng
Re: New XR 70
« Reply #9 on: 7 Jan 2005, 04:50 am »
Quote from: JnC
Try here:
Thanks my man.
Tonight i am hooking up my new xr 70 and panny dvd s97s with my rockets system!
Neild
Panasonic sa-xr70
« Reply #10 on: 29 Jan 2005, 10:32 pm »
Quote from: AphileEarlyAdopter
Quote from: Neild
Neil,
I have lots of earlier posts here and on AVS but in short I thought the xr50 sounds either a little sweetened or a little sweeter, though I'm not sure which.  Let me explain - some sounds on the xr50 sound splashier and with a touch more of the sound that's described as 'warm' or 'rich' on analog amps.  Now does that make it the better sounding amp?  I'm not so sure, because it almost seemed to me as if the xr50 might have been tuned to sound a bit more this way.  Those preferring a very neutral and unmodified sound might prefer XR45 which doesn't sound this way.
To oversimplify it, it would be like how a stereo with bass & treble boost might give the perceived or superficial impression of being better until you do some real rigorous listening.
Last spring I did extensive listening tests including one with 8 various musical passages.  The test was around seeing if new XR50's needed 'breaking in' but also included observations as to whether XR50's sound different, better, or worse than XR45's or XR25's.
In my conditions, XR45 was felt to be preferable in 5 of the 8 passages.  XR50 was overwhelmingly preferred for looks and ergonomics.
I was not able to discern significant audible difference between xr25 & xr45 incidentally even though we know xr45 has the superior electronics including power section.  Perhaps my conditions or speaker selection werren't such to prove any difference between the two.
XR45/25 were easily noticed as different from XR50 between even casual non-audio enthusiasts.  There wasn't as much consensus about which was better between the two.  In both subjective and A/B blind controlled tests, new out of the box XR50's were less preferred than used Panasonic receivers of both the old and new series.
I still have an XR45 that I'm selling for space considerations but I afraid sentiment might prevent me from going through with it.  It remains the favorite amp I've ever owned.
tvyankee
Panasonic sa-xr70
« Reply #11 on: 29 Jan 2005, 11:55 pm »
hello.
did you try them with balanced power?these units really love balanced power.
my 50 sounds really very nice with the bpt conditioner.
thanks
AphileEarlyAdopter
Panasonic sa-xr70
« Reply #12 on: 30 Jan 2005, 12:07 am »
Quote from: tvyankee
hello.
thanks
I second that.. Balanced power highly recommended.
I think Neil might be right about the XR50 being a little sweet. I never thought it to be harsh at all.
I just came back from Magnolia after listening to a Primare Integrated with Martin Logan speakers.  I think I like my Panny XR50 better. Fortunately, I was planning to buy the Primare but never did. I seems too warm to my tastes. More like the Audio Refinement Complete I had previously.
With the Panny, you hear the music, with audiophile amps you hear your equipment. It is much more realistic.
I think, I will get a Nordost Shiva power cord for it oneday.
