0 Members and 1 Guest are viewing this topic. Read 3697 times.
Maybe I'm in the minority or the demographic minority as I'm not a teen or in my 20's, but Tidal bugs me. I do like the service and quality, but they really have an emphasis on rap and hip hop.You open the app and that's all you see.....
... they really have an emphasis on rap and hip hop.
Perhaps it's time for the old fogies to band together with a request and/or complaint about not being able to customize the interface. What do you think?
Tidal's "Rap-centric" approach may be an artifact of its owner Jay Z and a number of other artists/owners. It is also likely a smart marketing strategy; the number of actual audiophiles who will pay for lossless streaming is far smaller than the number who prefer to stream for free or for a lower tier price. High end audio remains the territory of older men. The majority of popular music fans simply listen on whatever crappy reproduction system they own.
... which is funny because old men (I'm not getting any younger) typically begin losing hearing acuity and thus may not be able to fully appreciate the highest resolutions. On the other hand, maybe they need the highest resolution so that they can afford to give some of it up due to hearing loss.
......In my case, it, by default, will try to open the file in a format converter so that it can play the file. Which means it tries to convert the FLAC file to MP3. What do you think happens with the FLAC file served up by Tidal? My contention is that something has to convert the Tidal FLAC file to a playable format (MP3) in software most likely on your computer's sound card. The MP3 bits are then fed to your offboard DAC (presumably). ......
......As for Tidal's "Rap-Centric" approach, I don't care. What they offer me with the kind of music I like is beyond my wildest dreams.
I listen to Tidal in preference to my own server's ripped CDs (FLAC) exclusively. I hear no difference between the two. But, you have to question the whole premise involved in Tidal serving up FLAC files to your computer. If you select a FLAC file (one that's on your server) and try to "open" it with your OS default software for FLAC files, what happens? In my case, it, by default, will try to open the file in a format converter so that it can play the file. Which means it tries to convert the FLAC file to MP3. What do you think happens with the FLAC file served up by Tidal? My contention is that something has to convert the Tidal FLAC file to a playable format (MP3) in software most likely on your computer's sound card. The MP3 bits are then fed to your offboard DAC (presumably). This is not the case with JRiver, for example. JRiver takes the FLAC bits and sends them straight to your offboard DAC where it does what it does (way better than your sound card can). So, unless you intervene, Tidal's wonderful FLAC files don't make it to your DAC unconverted. Your expensive DAC is actually just processing MP3 files. At least, that's my contention. And that's also what my ears told me. I, too, was disappointed with Tidal's SQ. I then found that I needed an interface that allows Tidal's FLAC files to make it untouched over to my offboard DAC so it could work its magic. The interface that I bought, that accomplishes that, is Amarra.As for Tidal's "Rap-Centric" approach, I don't care. What they offer me with the kind of music I like is beyond my wildest dreams.
