SOLD!: Perreaux SA3 Class A Stereo Preamp w/dual phono inputs [MM & MC]
0 Members and 1 Guest are viewing this topic. Read 1604 times.
Bostown
  • BASS CLUB [Boston Audio Stereo & Social Club]
    • Second Time Sound - Audio Gear Re-Purposed
This is a slim line GEM of a preamp.
The Phono stage is good enough that it's been used as a stand alone in some systems and well worth the cost of ownership.
$SOLD!!! - PP / F&F or USPS Money Order
PERREAUX SA3
Specifications:
Input Sensitivity
High Gain (moving coil)............ 200μV
Low Gain (moving magnet)....... 2.8mV
Compact Disc................................... ........350mV
All other inputs ....................................... .110mV
Input Impedance
High Gain (moving coil).................................47kΩ
Low Gain (moving magnet)............................47kΩ
Compact Disc................................... ...............20kΩ
All other inputs ....................................... ........25kΩ
Input Overload
High gain................................... .. 35mV
Low gain ................................... 350mV
All other inputs ....................................... ......50V
Rated Output...............1.5Vrms into 10kΩ or higher
Maximum Output ........25Vrms into 10kΩ or higher
Main Output, Source Impedance ....................1kΩ
Tape Output Level.................................. .....110mV
Source Impedance.............................. ...............2kΩ
Minimum Recommended Load Impedance .10kΩ
Distortion (THD and IMD)
Phono inputs 0.005% 20Hz-20kHz rising to 0.01% before overload
All others less than 0.0009% 20Hz-20kHz at rated output
Noise (inputs loaded)
Phono, high gain (unweighted)-50dB re rated input
Phono, high gain (A weighted).-66dB re rated input
Phono, low gain .................... -86dB re 10mV input
Phono, low gain (unweighted).-78dB re rated input
Phono, low gain (A weighted)..-86dB re rated input
All others (unweighted) .......-100dB re rated inputs
All others (A weighted)........-108dB re rated inputs
Frequency Response
Output stage........................ 20Hz-50kHz, ±0.25dB
Channel Separation
All inputs .................................. 68dB 20Hz-20kHz
Phase Accuracy ............................ ±2° 20Hz-20kHz
Frequency Response
Output stage ........................ 20Hz-50kHz, ±0.25dB
Channel Separation
Dimensions
Width ....................................... .........19.0"
Height ....................................... ........1.8"
Depth.................................. ............. 13.0"
Weight................................. ..........12.0lbs
« Last Edit: 19 Mar 2017, 02:12 am by Bostown »
Bostown
SOLD!!!
