PIC 16F628A chip wanted
0 Members and 1 Guest are viewing this topic. Read 667 times.
« on: 12 Mar 2017, 11:55 pm »
I was wondering if anyone has one or two PIC 16F628A chips for sale?
Cheers
Re: PIC 16F628A chip wanted
« Reply #1 on: 13 Mar 2017, 03:41 am »
What app it run? CD player?
« Reply #2 on: 14 Mar 2017, 10:16 pm »
Hi FRM,
I did not know it is a programmable chip. Accidentally too much input signal voltage to pin 3. No schematic, just a board and parts layout. Here is the link from the purchase site.
http://www.ebay.com/itm/Frequency-Counter-Meter-1Hz-50MHz-for-Crystal-Oscillator-Digital-LED-DIY-Kits-/141640365757?hash=item20fa6c76bd:g:SfMAAOSwv0tVMLD4
They seem to offer no program for the chip. I found it difficult to communicate with seller, Tom.
Cheers
sandbagger
« Reply #4 on: 16 Mar 2017, 07:06 pm »
problem is you will probably have to contact the manufacturer to get a replacement as it is programmed
if your very very lucky you might be able to find someone with the same device, pull the chip, read it and burn a new copy.
BUT there is copy protection that can be turned on in the chip when programed so you probably cant even read it.
I do have a PIC programmer but havent used it in years.
« Reply #5 on: 17 Mar 2017, 01:33 pm »
Thanks for the information Sandbagger. Unfortunately, it is almost impossible for the seller to understand the questions I have asked him, as his English is extremely poor. However, for $7.50 (includes postage) I have ordered a new kit and will simply use that chip. I will also attempt to provide some input protection.
I checked and see there are others selling the same kit for even less, so I may contact them for another backup.
Cheers and thanks again Gents.
