SOLD FS: Nord One UP NC500MB 400WPC Mono Blocks
0 Members and 1 Guest are viewing this topic. Read 1497 times.
SHjb
« on: 12 Mar 2017, 01:40 pm »
I purchased these amps new in August 2016. They have less than 100 hours use. Wonderfully dynamic with 400 watts of power at 8 ohms. Silver color. As-new condition but I'll rate them 9/10 as they are technically "used".
Nord One NC500  mono blocks based on the Hypex NCore NC500. Twin SMPS1200A700 PSUs in each chassis. Nord Class A Discrete Input Buffer board with discrete Op Amps and Discrete Voltage Regulators.
The Sparkos Labs SS3602 op amps are installed. "These Produce a slightly warmer, softer, fuller sound than the Sonic Imagery 994’s. Slightly less detailed and would suit those after a more valve amp sound."
Sonic Imagery 994 op amps were also purchased from Nord and are included. "They have a wonderful airy precise sound without being fatiguing or analytical, and have a very deep soundstage."
Also included at no charge is a pair of Nord 1 meter Hypex Spec XLR to RCA Cables (original cost US $54.76).
Ships in original box and packing.
Original cost of amps and 2 sets of op amps was US $1933.50.
Asking $1199.  Reasonable offers considered- how can I make this work for you? Shipping to CONUS only. PayPal only, buyer pays PayPal fees and shipping cost.
From the Nord website: “The Nord One UP NC500MB Amplifier is our upgraded Mono Block amp. Using Nord Input Buffer Boards with high end discrete Sparkos Labs Voltage Regulators and a choice of Sparkos Labs SS3602 or the Sonic Imagery 994 discrete Op Amps, both run in full Class A.  And offers a richer, warmer, tonally dense musical sound with greater soundstage while maintaining all the benifits of the standard amp. Italian all aluminum case complete with 10mm faceplate, solid 44mm diameter aluminum isolation feet. Patented CHK Binding Posts, gold plated solid brass 60A binding posts, Switchcraft gold plated metal body XLR socket, Quality mains sockets and blue "Halo" illuminated front switch.”
Specifications
• Silver Finish Single Mono Block Case
• Hypex NCore NC500 Module
• Hypex SMPS1200A700 Power Supply
• Nord One UP Input Buffer Board Choice of Sparkos SS3602 or Sonic Imagery 994 Op Amps
• Mono Block Design
• Distortion: THD+N - - 0.001 % 20Hz
• Frequency Response: 0 - 50k Hz +0/-3dB
• Low Distortion: THD+N - - 0.001 % 20Hz
• High Input Impedance 51K
• 26 dB Gain
• Ultra High Damping Factor
• High Current Output Capable of driving 2ohm for the
   Most Demanding of Speakers.
   550W 2ohm
   700W 4ohm
   400W 8ohm
• Case W 240mm D 280mm H 90mm
   With Feet and Binding Posts W240mm D340mm H95mm
•Weight 4.2\Kg each
« Last Edit: 13 Mar 2017, 06:59 pm by SHjb »
ddark65
Re: FS: Nord One UP NC500MB 400WPC Mono Blocks
« Reply #1 on: 12 Mar 2017, 02:57 pm »
Pm sent
ddark65
« Reply #2 on: 12 Mar 2017, 03:24 pm »
SHjb
« Reply #3 on: 12 Mar 2017, 03:56 pm »
Sale pending
SHjb
« Reply #4 on: 13 Mar 2017, 06:59 pm »
Sold
