For Sale: Amplification
SOLD: Pass B-1 DIY Buffer
0 Members and 1 Guest are viewing this topic. Read 846 times.
walkern
10 Mar 2017, 07:16 pm »
This Nelson Pass designed B1 is built with standard BOM parts (no exotic caps or resistors), has two (switched on front) inputs and two outputs (I used it to drive a stereo amp and a powered subwoofer). It uses a pair of mono TKD pots so you can make balance adjustments if you like. Comes with the standard 24V DC wallwart, and is squeezed nicely into a compact black metal chassis. Works exactly as it should and sounds very clean and dynamic. Please note that there is no on-off switch (meant to be left on all the time), so if you want to turn it on and off you'd either need to add a switch or plug and unplug the wallwart adaptor on the back. No original box but will be carefully packed and shipped. Asking $160 plus actual shipping costs in CONUS.
Last Edit: 15 Mar 2017, 12:19 am by walkern
Dieterle Tool
I don't know what it is, but I wunt it.
Re: Pass B-1 DIY Buffer
14 Mar 2017, 02:43 pm »
What is the impedance on the TKD pots?
thx,
Dieter
walkern
Reply #2 on:
14 Mar 2017, 06:19 pm »
Hi Dieter,
Sorry but I don't recall off the top of my head. If I had to guess, I'd guess 25K or 50K, but I don't have my receipts any more.
And by the way, the item is sold as of about 5 minutes ago.
Neil
