What brand of internal wire do vandersteen models have
0 Members and 1 Guest are viewing this topic. Read 2164 times.
mgsboedmisodpc2
It seems the Quatros  have "Audioquest " cables.  Also should internal wiring be twisted?
mgsboedmisodpc2
Re: What brand of internal wire do vandersteen models have
« Reply #1 on: 6 Mar 2017, 09:26 pm »
The below image shows very expensive internal cabling Von Schweikert style....so can the chosen internal cable improve a crossover's performance
ctsooner
« Reply #2 on: 17 Mar 2017, 01:14 pm »
Richard loves using AQ wire. Just look at what he used as the wires in his crossovers.  Yes the wire makes a huge difference as do the chosen components of the crossover.
