0 Members and 1 Guest are viewing this topic. Read 27546 times.
I believe the RS5 is about 4.5" in diameter, which would give a nominal cone area of 10.13 in2. Assuming the RS8 has an 8" diameter, it's cone area would be 16 in2, about 60% greater than two RS5's.
These new RS8 speakers look mighty fine.I'm hoping they can provide enough body that a sub is not necessary. My current speakers are Vandersteen 1C's which have a listed frequency response of 38Hz to 22,500Hz. In practice I find their bass to sufficient for most music in my current listening environment. The Junior 8XRS is also listed as achieving an similar frequency response. I listen to a lot of 60s-70s rock on vinyl and like the pulsing drive of the distorted guitars. Would the RS8 be up to the task of fleshing out some classic rock?
is it possible to update the old compact hemps with the new RS8 drivers?
If your drivers have the six screw pattern, the new RS8 should drop right in, as he is using the same basket. Possibly the bass port may need tuning by shortening it or getting a longer one. Louis would know best about cabinet tuning with the new driver.
