PCB 102207 in 4B SST2
0 Members and 1 Guest are viewing this topic. Read 683 times.
nemir
« on: 2 Mar 2017, 11:38 pm »
Hi there.
I had my 4B SST2 converted from 110V to 220V after I moved to Australia by a 'certified' Bryston repair centre.
A few weeks later it failed,  and when I took it back to get repaired I was told that the soft start PCB 102207 needed to be replaced that the part cost $600 adn the replacement would be a further $300.
It seemed to me that this part was likely something that would have been replaced as part of the conversion.  Am I wrong in thinking this?
It also seems to me that this is a lot to charge for the replacement part,  and the work to replace it in the unit.
Am I wrong in thinking that..?
Cheers
  • The Demo is Everything!
    • http://www.bryston.com
Re: PCB 102207 in 4B SST2
« Reply #1 on: 2 Mar 2017, 11:45 pm »
HI
Email Mike at Bryston and he should be able to give you an idea on the costs.
[email protected]
james
