0 Members and 1 Guest are viewing this topic. Read 5182 times.
If the speaker's upper panels are out of phase it should be obvious. On the other hand, if the panels are out of phase with each other on the same speaker, this would be difficult to determine.OT, I just heard George's RM40's on the Tact system that you have and they were amazing. Night and day difference ...
You can measure phase of the panels with a fresh 9V alkaline battery. Touch the (+) lead to the (+) terminal of the lowest panel and the (-) battery lead to the (-) terminal of the uppermost panel. All three diaphragms should visibly move forward.All drivers are in phase in the RM30 and typical semianechoic FR is within 2dB from 40Hz to 10kHz.
Have to totally agree with BC on this one. EQ without room treatments is like sweeping dust under the rug.
It is not possible to do the battery test on the tweeter: the diaphragm moves too far and will break. We check phase at the factory. In addition I took the RM 30C's for Jose to my soundroom and checked them out; no problems and they sounded excellent.I believe most of Jose's measurements are misleading, as are most in-room measurements. Room modes and cancellations due to time delays (reflected energy from side walls, floor and ceiling) in untreated rooms give microphones fits.Room treatment yield ...
VMPS speakers + Room Treatments + Room Correction = AWESOME SOUND!!
Sorry for being OT.George,I’ve been interested in the TacT RCS preamps for a while, never got one do tothe volume of vinyl and SACD I listen to, but the 2.2X you can mix 1 or 2 sub’sin your room, and I think that’s great. How does the DAC in it sound?Pete
I don't have any room correction, but you can add me to the list of believers in room treatments. This week my new wall panels from Acoustics First arrived. I am amazed at the difference they made. I put them behind the live end of the room and one at the first reflection point (not visible in the picture below). One word: Clear. Everything sounds so much clearer now. I notice it especially in the high frequencies and percussion. Each drum is more distinc ...
