Considering a different sub / will this be an upgrade ?
0 Members and 1 Guest are viewing this topic. Read 1506 times.
stlrman
Someone is selling a
https://www.cnet.com/products/velodyne-dls-3500r/specs/
For $100 , although I may see if he wants to trade for something .
This sub went for $499 and has a remote , way more watts than my Polk.
I am running a Polk 10 inch from CL that I got for $60
PSW10
https://www.amazon.com/Polk-Audio-10-Inch-Powered-Subwoofer/dp/B0002KVQBA
I am wondering if going to the Velo would be a big and powerful increase? For movies only. Room is 14x16
Thoughts?
Thanks!!!
jarcher
  • It Just Sounds Right
Re: Considering a different sub / will this be an upgrade ?
« Reply #1 on: 2 Mar 2017, 06:29 am »
Keep the Polk and save up for something better. W/ a 6.5 active that velodyne even w/ the 8 inch passive and marginally more power is not going to be an improvement for home theater.
You need to find yourself a used SVS if you can pry one away from someone. Something with a 12 inch or better driver and decent power (over 100wpc continous - although many class d amp subs have a lot more). There's just no replacement for displacement when it comes to home theater subs.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #2 on: 2 Mar 2017, 09:22 am »
Here: http://www.audiocircle.com/index.php?topic=148815.msg1591681#msg1591681
It's sold on Amazon...
Best,
Anand.
« Reply #3 on: 2 Mar 2017, 12:19 pm »
+1
And I'd add that the standard advice is to go with a ported sub for HT and sealed for music/HT.  Used subs can be iffy as they frequently get abused, so check out the seller too.  Amazon has a deal going on currently for a good new 12 inch/400 watt sealed SVS sub:
https://www.amazon.com/gp/product/B009F8Y7SO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=AAK72K4OIWDXL&tag=tbdirect-20&ascsubtag=d208cc47-ea8b-4edb-9815-c977cb3ab132
stlrman
« Reply #4 on: 2 Mar 2017, 05:36 pm »
Thanks gentleman!! Looks like I'll keep what I have.
Plus I have an 8inch Pioneer that I can run along side the 10 inch to get some more oomph.
