Rogue Audio ST-100 - Black (5 months old) SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 1311 times.
shahed
« on: 28 Feb 2017, 09:04 pm »
Rogue ST 100 stereo amp in black. The unit is about 5 months old and has around 500 hours on the tubes. I'd rate it as 9/10.
Bought it as mint demo (less than 50 hours use) from authorized dealer. It'd be very very hard to find a better amp at this price range.
Asking $SOLD plus shipping. If using paypal add 3% or use paypal gift option. It'd be great if someone local wants to pick it up. I'm in NYC area (11106).
Spec: http://www.rogueaudio.com/Products_100.htm
General Features: [back to top]
- Ultra-wide bandwidth output transformers
- Massive fully regulated high voltage supply
- Matched quad output tubes
- Heavy-duty gold plated RCA inputs
- Heavy-duty gold plated binding posts
- User selectable 4 and 8 ohm output taps
- User selectable triode or ultralinear output
- (4) KT120, (2) 12AU7, (2) 12AX7 tube complement
- Built in bias meter
- Integral tube cage
- Machined aluminum faceplate
- Mechanically isolated transformers
- Heavy (2 ounce) copper circuit board
- All precision components
Specifications: [back to top]
- output power: 100 WPC minimum
- input impedance: 200K Ohms
- frequency response: 5Hz - 50KHz ± 1dB
- THD: <0.1% typ., <1.0% at rated power
- input sensitivity: 1.0V RMS
- dimensions: 18"W x 15¾"D x 7"H
- weight: 60 lbs.
- power requirements: 115/60Hz or 230V/50Hz
10Audio Review: http://10audio.com/rogue_stereo100.htm
« Last Edit: 20 Mar 2017, 05:43 pm by shahed »
shahed
Re: Rogue Audio ST-100 - Black (5 months old)
« Reply #1 on: 13 Mar 2017, 06:09 pm »
Bump!
