Low Hum from Mullard Replica
0 Members and 1 Guest are viewing this topic. Read 2295 times.
Adarsh
« on: 26 Feb 2017, 02:04 pm »
Hi
I recently became the owner of a Mullard 5-10 replica. The amp makes a low hum when turned on and nothing connected. Is this noise coming from the tubes?
I get about 30dB when OFF and 35dB when ON. Measured the hum from near the speaker.
Re: Low Hum from Mullard Replica
« Reply #1 on: 26 Feb 2017, 03:22 pm »
What do you mean say nothing connected?
If its no speakers connected your output transformers will come in short circuit due lack of load (speakers) hence the hum, they will become hot also til something burn.
Adarsh
« Reply #2 on: 26 Feb 2017, 05:53 pm »
I'm sorry, I meant to say that I can still hear a hum with no devices connected on the input (ruling out any source that might be causing hum). I have speakers connected on both channels and the hum is coming from the speakers.
shooter
« Reply #3 on: 26 Feb 2017, 07:10 pm »
Did you short the input to ground when measuring? If not there will be hum.
« Reply #4 on: 26 Feb 2017, 07:22 pm »
It may be self noise from the circuit, power trafo or OPT, bot the tubes imo.
Adarsh
« Reply #5 on: 26 Feb 2017, 07:39 pm »
No, I did not. I have read about devices which defeat the ground loop pin but that could have fatal consequences. The AC connector is a schuko type with an integrated ground pin that connects to the terminal in the wall socket.
Adarsh
« Reply #6 on: 26 Feb 2017, 07:40 pm »
I am fairly new to tube amplification. What does one do when faced with this situation? I have never experienced this with solid state amplification.
shooter
« Reply #7 on: 27 Feb 2017, 12:18 am »
Let me clarified my comment, I am not talking about lifting the ground on AC, in order to test the noise of your amplifier you have to use a shorting plug on your input RCA to measure, an unconnected open input will have a lot of noise on your speaker terminal.
« Reply #8 on: 27 Feb 2017, 11:12 am »
Most tube amps have a very low hum when connected to a hi sensitivity speakers, not sure if its your case.
If your prob is a abnormal intense hum you need take the amp to a experiencied tube amp technician.
JohnR
« Reply #9 on: 27 Feb 2017, 11:18 am »
Hi
Noice :D
I'm guessing you are talking about mechanical noise from the power transformer.
