Preamp hum only when pot at zero. Otherwise on nois
0 Members and 1 Guest are viewing this topic. Read 1083 times.
frankheilig
« on: 24 Feb 2017, 11:37 pm »
Not sure if this is the right place for this question but I just completed building a 4S preamp with volume pot on the input.  All works well except when pot is at zero.  Then a significant hum appears.  The hum is somewhat less when throwing the signal to ground.  Help please!
Speedskater
  • Kevin
Re: Preamp hum only when pot at zero. Otherwise on nois
« Reply #1 on: 25 Feb 2017, 12:44 pm »
I think that you have a bad pot. the pot's wiper is losing contact at the zero position. Disconnect the wires and check it with an Ohm-meter.
