Torus Isolation transformers
0 Members and 1 Guest are viewing this topic. Read 1314 times.
Ryder35
« on: 20 Feb 2017, 05:23 pm »
Hi
I know Bryston do the BIT range now but they do not seem to be available in the UK. I am looking at the Torus Power options, specifically the TOT Max that has an 8 amp rating into 240 volts and a power rating of 1840Va. Will this be enough to run my B135 along with my sources (LP12, Aria Phono stage, Auralic Aries and Vega?)
Thanks, I am really confused by the use of amps and how that relates to peak wattage on the amp!
Grant Hill
Re: Torus Isolation transformers
« Reply #1 on: 21 Feb 2017, 03:48 pm »
Hi,
as far as I've understand, the difference between Bryston BIT an Torus is only in the faceplate... guys correct if I'm wrong.
Rod_S
« Reply #2 on: 23 Feb 2017, 06:49 pm »
I believe so, they are one and the same, same prices as well I've been told.
ketcham
« Reply #3 on: 23 Feb 2017, 07:00 pm »
I ordered the Torus Power 75A wall mounted unit which I take delivery tomorrow and install Saturday.  You both are correct.  Bryston is re-branded Torus which Plitron manufactures.
