0 Members and 1 Guest are viewing this topic. Read 9613 times.
Really liking the tang band so far about 40 hours. Some real ups and downs with it though. Perhaps more than any other driver I have ever had.
Are you suggesting that crossing them over at 450 Hz will help them stabilize / break in?
Even without reaching up to 450 Hz, I would think the servos would be superior in every respect to the Neo 15s....In any case, wouldn't it be better to run the bass drivers with plate amps?
Exactly what I was thinking.....then I plopped the passive x-over in......and now I think different.
Hi Perry,A few questions if you don't mind... I'm guessing the 1808 doesn't operate full range with the crossover, otherwise you'd just use an inductor, right? Is that a first order crossover? What are you using to power your PAP? Finally, how do these compare to your other OBs?Thx - John.
