WTB: Zenwave D4 RCA inteconnects
0 Members and 1 Guest are viewing this topic. Read 1344 times.
MttBsh
« on: 14 Feb 2017, 11:13 pm »
Pls let me know if you have a (meter or .5 meter) pair you can part with, thanks!
DaveC113
  • ZenWaveAudio.com
Re: WTB: Zenwave D4 RCA inteconnects
« Reply #1 on: 14 Feb 2017, 11:41 pm »
PM goskers. He's going with a LIO + X1 so he might sell... he's got a 1/2 meter pair.  :thumb:
MttBsh
« Reply #2 on: 14 Feb 2017, 11:45 pm »
Thanks Dave! will do..... your cables are absolutely amazing.
goskers
« Reply #3 on: 15 Feb 2017, 03:45 am »
The ones that he has now ARE my old ones  8)
DaveC113
  • ZenWaveAudio.com
« Reply #4 on: 15 Feb 2017, 05:00 am »
Thanks MttBsh! And good luck with the search, I definitely understand wanting to save some cash. It's too bad you don't need XLRs...  :wink:
Glad you found a good home for them goskers.  :)
MttBsh
« Reply #5 on: 15 Feb 2017, 06:01 am »
Thanks Dave - I felt I owed it to myself to search - but if nothing turns up out there I'll be knocking at your door  :thumb:. There really is only one problem with the D4s - once you hear a pair there is no going back. They're the only ICs I will use going forward.
Wig
« Reply #6 on: 16 Feb 2017, 06:33 am »
Daves D3.5 are awesome as well!
Wig
DaveC113
  • ZenWaveAudio.com
« Reply #7 on: 16 Feb 2017, 08:02 pm »
Wig
I'm having some slowdowns getting the D3.5 up on my site, I just transferred control of my site to someone else so hopefully there will be some updates coming through soon.
The 3.5s are, as the name suggests, about halfway to the D4, they use the WBT 0102 Ag RCA plugs in place of the FP-108(R). I'm not using the FP-101(G) at all anymore, another change I need to make to the site.
Thanks for the props too, much appreciated... it makes it all worthwhile.  :thumb:
