E-715 Cerwin Vegas
0 Members and 1 Guest are viewing this topic. Read 1058 times.
sickandtwisted
E-715 Cerwin Vegas
« on: 14 Feb 2017, 02:28 pm »
I have a pair of E-715 Cerwin Vegas with the 15 inch speakers. I am replacing all three speakers. Do I make the replacements all 8 ohms?  I bought the 500 watt replacement woofers @ 8 ohms. I bought 8 ohms 80 watt horn type tweeter. I still need a 5 inch mid, should I keep everything at 8 ohms, or will it even matter?..thank you.
Danny Richie
    • http://www.gr-research.com
Re: E-715 Cerwin Vegas
« Reply #1 on: 14 Feb 2017, 03:12 pm »
You'll need to replace the drivers with the same drivers otherwise the crossovers will need to be re-designed.
