0 Members and 1 Guest are viewing this topic. Read 6824 times.
I am surprised so few play with the 92 db B&G Neo 10.
Have you listened to the MW16P yet? Its one of the very few widerange drivers I might tolerate sans tweeter.Of course a tweeter will add some air at the very top. If OB, I hope you mean a lot of 8s!cheers,AJ
AJ Do I need multiple 8s if I am using the GR research subs?
Hi Jim,If I recall, the GR servo 8s are only available in multiples (2-3?). A single ob 8 won't have much of what I would call bass, unless one listens at fairly low volume. Ignore that midrange graph I posted, might be time for the optician . Your Satori woofer should work well OB, but 275 passive might be a stretch without a very large baffle and/or low sensitivity (using a shelving filter to get your F3). Active, no prob.cheers,AJ
OK so we keep screwing this up, I am using dual 12 inch GR subs. Now I am thinking of using the 8 inch satori MW19 as the MID to bridge from 275hz to 2khz. If that still wont work then I need to pick another driver.
I am using a ModWright KWA100SE on the toppers. IIRC, the MW16 doesn't seem to have the breakup at 2khz. There are lots of ways I can go with this
