Super Tower /R SE 10" midbass
0 Members and 1 Guest are viewing this topic. Read 2395 times.
AVB
« on: 12 Feb 2017, 06:01 pm »
I picked up a set of these in trade and they look great. A little less bass than I would have thought but I haven't played with or even looked at the PR yet.
My question is if anyone knows what 10" midbass originally came with these?  The left speaker has woven carbon fiber with phase plug (magnet # X5453 1056 9606) and the right has a smooth coated finish with phase plug (magnet #X5070 1056 9219)
If both are acceptable and just came from different years of production which would be preferred? Are replacements or substitutes available cause I can't find them? And for a last wild shot in the dark.....does anybody know the specs so I could try to source a replacement if needed sometime down the line?
« Last Edit: 14 Feb 2017, 08:49 pm by AVB »
RSorak
Re: Super Tower /R SE 10" midbass
« Reply #1 on: 13 Feb 2017, 04:57 pm »
Generally the carbon fiber cones were upgrades over the non carbon ones....When I bought my Super Towers the carbon cones were an available upgrade that I got.
AVB
« Reply #2 on: 13 Feb 2017, 07:00 pm »
You didn't say if yours was an ST /R SE or just a regular a ST /R.
Since I posted this every ST /R SE pic that I've found shows a woven 10" midbass which makes me think that is the original.  While the other isn't a woven pattern that doesn't mean it isn't carbon fiber too (AFAIK).  However, that doesn't mean you aren't correct. This could be an early set that was upgraded and when the woven driver was damaged the other midbass was installed.  The only paperwork I found says that the ST /R SE comes with a carbon fiber midbass which would be the woven style based upon the pictures. I wish there was a way to tell the composition of the smooth cone midbass which would tell me if it was a substitute from VMPS since it has their numbering scheme on the magnet. The previous owner says that he got them that way so there isn't any help there.
RSorak
« Reply #3 on: 14 Feb 2017, 05:19 pm »
mine are ST R/ SE's
ZAKski288
« Reply #4 on: 14 Feb 2017, 07:16 pm »
The VMPS SuperTower /R  have 12" mid bass drivers, not 10".
« Last Edit: 14 Feb 2017, 10:28 pm by ZAKski288 »
AVB
« Reply #5 on: 14 Feb 2017, 08:32 pm »
True, but the SE version has a 10"
duck851
« Reply #6 on: 14 Feb 2017, 10:17 pm »
Have you searched the "X" numbers in this circle?  Have you perused the sticky thread on Replacement Drivers?
AVB
« Reply #7 on: 15 Feb 2017, 01:30 pm »
Not only searched the Circle but google too = so far with no luck.
