626R speakers
0 Members and 1 Guest are viewing this topic. Read 1439 times.
Shear Bliss VMPS
626R speakers
« on: 11 Feb 2017, 03:19 am »
Hello,
Does anybody have a source on 4 ohm L-pads ?? My 626R is rated as a 4 ohm speaker so think I need the 4 ohm, all I can find is the 8 ohm pads so far. Maybe I am wrong and the 8 will be fine, don't know ... anybody have more info on this ?? Thanks
DW
Evoke
    • EVOKE Planar Loudspeakers
Re: 626R speakers
« Reply #1 on: 11 Feb 2017, 03:23 am »
An 8 ohm L-pad should be fine - you can source them from Parts Express.
Shear Bliss VMPS
Re: 626R speakers
« Reply #2 on: 11 Feb 2017, 04:41 pm »
Thanks Evoke,
Now the best or proper wattage, as there are 15 watt to 100 watt ??? Thanks, again!
DW
Evoke
Re: 626R speakers
« Reply #3 on: 11 Feb 2017, 05:02 pm »
I use the 15 watt on my smaller speakers and the 100 watt on Eddie. I totally over-engineer that crossover. Take a look at the existing one... If it's smaller and round - about 1" it's 15 watt. If it's larger like 1 1/2" to 2", maybe square it's 100. You might consider changing all the L-pads in both speakers while you are at it and get it over with. Time can affect them so it might be a matter of time before the others act up.
Hope this helps.  Take care of those 626's !!!!!  :D
Mark
