Audio/Video Gear and Systems
The Lab
sts9fan
Anyone have experience with Deflex panels?
0 Members and 1 Guest are viewing this topic. Read 1464 times.
Christof
Industry Participant
26 Nov 2004, 02:22 am »
I'm selecting dampening materials to line the inside of a sealed 3-way. There are so many possibilities and so many different views on dampening that I'm having a hard time pulling the trigger. Do you guys have any ideas on good materials? Deflex sounds like a neat material to line the back wall with but I have never used it nor know anyone to use it. Though I'd check here first before throwing $ down the drain.
Also there is a Deflex panel designed for sub enclosures but I was under the impression that standing waves do not present problems w/ subs, it is only the higher Hz waves that we need to worry about...is this true or would it be worth a try to throw Deflex pads inside my subs as well?
Here is some Deflex info:
http://www.tnt-audio.com/accessories/deflex_e.html
Christof
rha61
26 Nov 2004, 11:08 pm »
yes i have Deflex panels in my DIY speakers for 5 years
they work very well , better than any damping material i've tried
alain
The Lab
sts9fan
