SOLD: Funk Audio 18.3 subwoofer
0 Members and 1 Guest are viewing this topic. Read 1570 times.
poseidonsvoice
    • 2 channel/7 channel setup
« on: 4 Feb 2017, 04:36 pm »
Due to changes in home cosmetics, I have to very reluctantly let this subwoofer go :cry:. This is the finest subwoofer I have heard both for HT and for 2ch, specifically in the mid bass. I have experience with SVS, PSA, Rythmik, Seaton Sound, Legacy, etc...but Funk is the cream at the top. If you are looking for a sub that competes at the level of other subs in the four to five figure price category, look no further, this is it. This sub is the state of the art in subwoofers. For those of you familiar with the Funk 18.0, this 18.3 has essentially double the output of a Funk 18.0 at frequencies less than 40Hz and has the equivalent output above 40Hz. Crossover frequencies can easily be as high as 200Hz and topology is completely variable from 1st to 4th order with the very powerful DSP module. You can implement nearly any kind of parametric EQ you desire for your desired response curve. Audiogon 9/10 just for a few blemishes that show up on flash photography.
Performance specifications
Variable tuning; 15/18/21hz
+/-3db variable from 13-30hz, to 40-150hz
121db RMS output at 2m ground plane
Response to 12hz in room
Amplifier
2.4kW X1 M3
Dual XLR inputs
USB interface to PC
Automatic Dual voltage 115/230V
Output Power
2400 watts RMS 4800 watts peak power, per channel
120Db dynamic range
0.01% THD at 1800 watts RMS output
DSP Features
Parametric EQ, 5 filter types, 10 bands/ch
High and low pass crossover, 10 slope options
Adjustable Delay
Adjustable level
Adjustable limiting
Auto on/off
Physical features
One piece aluminum Chassis/heatsink
Black anodized finish
20 Amp rated mains input, power cord, circuit breaker/power switch
10 foot heavy gauge detachable power cord
Hand made by Funk Audio
Driver
TSAD18v1
Hand built in house by Funk Audio
4.5” Aluminum voice coil
High energy Neodymium magnet structure
Dual Aluminum shorting rings for reduced distortion
Linear Inductance +/-5% through 3" peak to peak travel resulting in very low distortion, and clean midbass.
Cast Aluminum frame
Anodized aluminum dust cap
Carbon fiber/paper composite cone
Tall profile treated foam surround
10” diameter spider
3” P-P excursion
Under spider venting
Vented Pole piece
Assembled with high temperature epoxies
Passive radiators
Dual 18" passive radiators
Cast Aluminum frame
3” P-P excursion
Enclosure
Wengé veneer with a clear finish.
Baltic birch plywood construction.
1.5” thick front baffle
1.5” thick top/bottom
Extraordinarily well braced
Curved laminated side walls
23" wide 44" high 21" deep
Standard with rubber feet
Weight
Estimate 160-170 lbs shipping weight
Shipping will be by freight only, unless local buyer is found. Zip code is 28697.
Price: $OLD + shipping (estimate $300-$400). The list price of this product starts at $4340.
Serious enquiries only. There will be some concession on the price for a local delivery, within 150 miles of the zip code 28697. In addition,
to the new owner, I will ship an Auralex Subdude HT isolation platform specifically for this sub along with special footers from Herbie completely gratis.
Passive radiator photo:
Best,
Anand.
« Last Edit: 23 Feb 2017, 05:34 pm by poseidonsvoice »
