Converting a pair of N3S to N3
0 Members and 1 Guest are viewing this topic. Read 1151 times.
kramertc
« on: 4 Feb 2017, 03:05 pm »
Hi Danny,
I have 3 N3S using as LCR at home that I have been enjoying immensely for the past few years.  I have the bug to convert the left and right to the floorstand version and have a couple of questions.
Is the crossover different for the N3?
Do you know if anyone is still producing flatpacks for these?
Thanks.
Danny Richie
    • http://www.gr-research.com
Re: Converting a pair of N3S to N3
« Reply #1 on: 6 Feb 2017, 02:02 pm »
The crossover is the same. The transmission line design only effects the lower end.
I don't know about flat packs though, but we might be able to find someone that can knock some out.
kramertc
« Reply #2 on: 6 Feb 2017, 04:12 pm »
Danny,
I'm crossing over the lower frequencies to a sub already.  I wouldn't gain much benefit then by converting the N3S to N3, right?
