Yamaha A-S2100 MM/MC Phono Stage
0 Members and 1 Guest are viewing this topic. Read 2033 times.
TKonrad.NOLA
« on: 31 Jan 2017, 05:05 am »
My apologies if this is a stupid question, but how do I know if my MC input is made for  a low output or high output cartridge?
GentleBender
Re: Yamaha A-S2100 MM/MC Phono Stage
« Reply #1 on: 31 Jan 2017, 10:25 am »
Not sure, but maybe this will help. It is the manual with specs. http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=64109
Blackmore
« Reply #2 on: 31 Jan 2017, 02:11 pm »
The manual says the MC loading is 50 ohm so that will work with low output moving coil.  High output moving coils would be happy into the MM input. What cartridge are you considering?
audio.bill
« Reply #3 on: 31 Jan 2017, 04:28 pm »
Phono inputs marked MC are always designed for low output MC cartridges. Some ultra-low output MCs may not have enough output for adequate gain with a specific MC phono stage. High output MC cartridges are designed to go into standard MM phono inputs as far as both their loading and gain characteristics.
TKonrad.NOLA
« Reply #4 on: 4 Feb 2017, 02:43 pm »
Thanks everyone.  I want to update my 2M Red and thought about getting a moving coil cartridge.
