Cheaper class d audio amp?
0 Members and 1 Guest are viewing this topic. Read 4046 times.
NEXTLEVEL5
« on: 29 Jan 2017, 01:30 am »
Hi, I am looking for a cheaper class d audio amp that can put out 150-250+ watts into 8ohm stereo and have a case. Are there any cheap kits out there for purchase? Thanks, NL
I.Greyhound Fan
Re: Cheaper class d audio amp?
« Reply #1 on: 29 Jan 2017, 04:16 am »
Oscillate
srb
« Reply #3 on: 30 Jan 2017, 06:30 pm »
NEXTLEVEL5 is looking for an amp with 150W - 250W+ per channel @ 8Ω.
The CDA-224 for sale in the Trading Post is 60W/ch @ 8Ω; the most powerful amp from Class D Audio is the CDA-500 or SDS-500 with 250W/ch @ 8Ω only.
cujobob
« Reply #4 on: 30 Jan 2017, 07:01 pm »
How cheap are you looking for? These aren't cheap, but I have heard very good things about the Crown XLS 1502 and higher (the 1002 will have higher S/N ratio)
steve k
« Reply #5 on: 30 Jan 2017, 10:38 pm »
Hi Nextlevel5:
This thread will give you many opinions of these amps and many ideas of how to build these amps--from cabinet drawer cases to beautifully machined cases. It's long but a fun read. I'm still using ClassDAudio amps but I bumped up in power to an SDS-250 and SDS-500--same speakers as Maggies suck up power from any amp.
http://www.audiocircle.com/index.php?topic=76400.0
walkern
« Reply #6 on: 16 Feb 2017, 05:02 pm »
Hi NL5,
I've got an SDS 250 ClassDaudio amp that I'm no longer using, and was planning to sell.  It is 125 wpc (not your minimum of 150 wpc into 8 ohms, but close) and is installed in a simple aluminum case with a SMPS that puts out the requisite 48 DC.  The amp probably weighs less that 5 pounds (one of the reasons I went with the SMPS) and has Vishay fixed resistors at the inputs (rather than the adjustable pots that came with the kit ... although I think I could probably find the pots if you really wanted them), and is certainly not a piece of audio jewelry, but it works fine and sounds terrific.  I would be happy to send you photos if you are interested, and am flexible on pricing.  If you read through the LONG audiocircle thread topic linked by Steve K you'll see some comments in there from me regarding various input resistor options I tried.
Neil W
Letitroll98
  • Too loud is just right
« Reply #7 on: 16 Feb 2017, 11:53 pm »
NuPrime STA 9?
skalos
« Reply #8 on: 20 Feb 2017, 03:21 pm »
i have the ClassD sds-470c amp. 300wpc 8 ohm, 600wpc 4ohm. Fully built $695 but i believe you can buy a kit even though not listed on the sight.
JohnR
« Reply #9 on: 20 Feb 2017, 05:07 pm »
Worth a look here: http://hifimediy.com/amplifiers/diy-amplifiers
