0 Members and 1 Guest are viewing this topic. Read 8270 times.
I have been looking for an affordable or simply DIY solution for some diffusers and ran across this, any thoughts:https://www.2modern.com/products/acoustic-weave-tiles-set-of-12Made of recycled paper and seems like the designs would diffuse sound waves, but wasn't sure if the material had to be of a certain sturdiness...
According the Floyd Toole's "Sound Reproduction" diffusion works best on side walls. And don't expect a tiny panel (like a 2ft x 2ft) to provide much benefit. I use 3 tall randomly filled bookcases along the side walls (like Toole uses at home) that are aesthetically pleasing and functional.
Would those paper tiles work if the backside was filled with spray insulating foam? They seem like a very attractive design and if there is a cheap way to enhance their acoustic properties (either absorption or diffusion) they could be a very eye pleasing design and would not require as much work.
Chris,My bookcases are nice looking but cheap 30" x 72" x 12" cherry 5 shelf units containing books, papers, and some odds & ends.
Doubt if foam would make a big difference. Lightweight concrete would be a better material IMO, but doubt it would adhere for long. And you'd still have limited effective frequency range.
"Really, you don't think that the CRL foam, acoustic foam, designed for small or make shift studios would work?"I have tried some of the foam products. None of it seemed to do much. Those items that I purchased from Gik and the DIY units using Owens Corning 703 have worked quite well.
Sonny, I still use some Sonex 24x48x2 panels for my 1st and 2nd reflection points that do make a difference. I bought (11) of these http://www.thefoamfactory.com/acousticfoam/bassbroad.html and put (3) in each corner, and then straddled the corners with GIK 244's.These corner units helped tighten up the bass and really cut down on slap echo. After adding the corner 244's, I mounted another 244 horizontal centered on the front wall, and another 244 directly behind the LP. Adding the GIK's took the room up a couple levels for the better. My next step is replace the Sonex with GIK 242's and add scatter plates to them.
