Empirical Audio OverDrive (loaded with upgrades)
0 Members and 1 Guest are viewing this topic. Read 1408 times.
ChrisVH
    • http://www.vhaudio.com
« on: 27 Jan 2017, 06:31 pm »
https://www.audiogon.com/listings/da-converters-empirical-audio-overdrive-se-usb-dac-with-all-current-upgrades-2017-01-26-digital-53153-north-prairie-wi
For sale is my Empirical Audio OverDrive Signatrure (SE) USB DAC with all the available OverDrive Signature upgrades, which include: D/A Hynes Regs, Analog Hynes Regs, Ground Plane
mods, USB Hynes, CuTF V-Caps, Empirical TurboClock, etc…
This unit has the older style chassis, and I believe was one of the first one or two units Steve made, before moving to the new chassis style. Thus, the deep discount you'll get on this unit vs a 'loaded' version using the newer style chassis.
Unit comes with all original boxes and manual, all AC adapters, and factory supplied cable that sends the power from the Substation to the OverDrive. Current software drivers may be obtained from Empirical Audio, and are based on M2Tech drivers.
More information on this World-Class DAC may be found here: http://www.empiricalaudio.com/products/
Measurements (Measured at 24/96):
THD+N (1kHz @ 0dBFS): -100dB
THD+N (1kHz @ -20dBFS): -105dB
Crosstalk (typical @0dBFS): -118dB
Crosstalk (@ 20kHz 0dBFS): -110dB
Frequency Response (-10Hz to 20kHz): -0.6dB
IMD (with 100K ohm load): -106dB
Dynamic Range (A-weighted 1kHz): 106dB
RCA Output Level: 1VRMS or 2.3VRMS
XLR Output Level: 2VRMS or 4.5VRMS
These links show the impulse response of the Overdrive DAC at 24/96 and 24/192. Hardly any pre-ring and the pulse gets almost to 1.5V (the input level). Pulse on the 24/96 reaches 1.233V. Other DACs have more pre-ring and never get anywhere near the amplitude of the input signal. This demonstrates the fast slew-rate of this DAC and the grip that it has on transients.
Impulse Response @ 24/96
Impulse Response @ 24/192
Inputs:
USB 2.0, Mac or PC, up to 5 meter USB cable – up to 24/192 supported
S/PDIF coax – BNC (RCA adapter included) – 44.1, 88.2, 96 and 192 supported at 16 and 24-bits
I2S (Empirical standard RJ-45) – 44.1, 88.2, 96 and 192 supported at 16 and 24-bits
DC power (+12VDC, -18VDC, +18VDC) from included Substation AC"
Outputs:
RCA left and right channels
XLR left and right channels
Controls:
Input Select
De-emphasis Select
Digital Filter Select – High, Medium, Low
Line/Volume Select – recessed
High/Low gain Select – recessed
Volume knob
Internal jumpers for 3 volume ranges
Included:
Overdrive SE DAC
Substation AC power supply
DC power supply umbilical cable
5 meter USB cable
BNC to RCA adapter
CDROM with PC/Mac installation software
RCA to Phone-jack Headphone adapter – only high-impedance headphones supported
Smoke-free, pet-free environment.
The unit will be safely DOUBLE-BOXED and INSURED with lots of packing.
NOTE: Seller reserves the right not to sell to buyers with less than excellent feedback.
Buyer will pay for shipping including insurance. 3.5% fee will be added for Paypal or Credit Card U.S., 4% for Canadian Paypal or Credit Cards. I will also take Cashier’s Checks, Money Order, or bank wire transfer, and can ship out when funds clear (up to 14 days for a Cashier’s Check). I ship via  UPS and get reasonable rates.
Legitimate offers will be considered; low-ballers will be politely ignored.
I will ship outside of the US or Canada after bank wire transfer is completed. This unit is 110-120V, 60 Hz AC.
Condition is excellent, but rating 8/10 simply because this is the older chassis.
ChrisVH
Re: Empirical Audio OverDrive (loaded with upgrades)
« Reply #1 on: 9 Feb 2017, 10:48 pm »
Just reduced to $2,999. This is a 'steal' for a fully loaded OverDrive SE.
ChrisVH
« Reply #2 on: 20 Feb 2017, 11:31 am »
Last price reduction to $2,799. The current identical unit sells for $8,249 from Empirical Audio direct. The only difference between this, and the currently sold unit, is this has the older style chassis.
J Payton
« Reply #3 on: 20 Feb 2017, 11:49 pm »
A quick question. Does the unit play 24/192 from USB? In your photos the chassis states 24/96 max for the USB input. I then went to Empirical Audio site and the unit there shows 24/192 which is different from what your unit states. Which is correct?
JP
