Navigating DVD -A or Dual disk without a monitor
0 Members and 1 Guest are viewing this topic. Read 924 times.
Phil
« on: 24 Nov 2004, 06:27 pm »
Since I'm a two-channel type (luddite) and have no experience with DVD-A, I'm wondering if all such disks (and dual disks), can be played in two channel mode without navigating via an attached monitor/display.
I'm ineterested in a universal player but don't anticipate attaching a CRT.
If all DVD-As cannot simply be plopped into the machine and the play button pushed, is there a way to indentify the ones that are user friendly?
thanks for the info.
BobM
« Reply #1 on: 24 Nov 2004, 06:31 pm »
Unfortunately, playing back DVD-A's wqithout some type of monitor can be painful. I use a portable DVD player when I need it.  I got it for long car rides with the kids. It is ideal, and only cost about $150.
If you have a need for one anyway this is the easiest path.
Enjoy,
Bob
Phil
« Reply #2 on: 25 Nov 2004, 12:54 am »
Bob,
thanks for the info.  good suggestion.  I was afraid of that.   Guess this is the reality of being two-channel in a multi-channel world.
Phil
rbrb
« Reply #3 on: 25 Nov 2004, 05:07 pm »
I have seen small (6"-8") B&W TV's at places like Wallmart for really cheap. Connect it with the composite video cable directly to the DVD-A player.
These units are small enough to hide beside your listening chair.
