JRiver
0 Members and 1 Guest are viewing this topic. Read 2040 times.
Derockster
JRiver
« on: 26 Jan 2017, 12:10 am »
Good evening All,
I just acquired a M2TECH HiFace USB to Coaxial converter.
My question is do you need to set JRiver to output the audio signal through the USB port.
derockster
Phil A
Re: JRiver
« Reply #1 on: 26 Jan 2017, 01:05 am »
I'm sure there's info on places like here:  https://yabb.jriver.com/interact/index.php?topic=56403.0
Phil A
Re: JRiver
« Reply #2 on: 26 Jan 2017, 01:06 am »
wushuliu
Re: JRiver
« Reply #3 on: 26 Jan 2017, 03:08 am »
Good evening All,
derockster
You should yes. I don't recall if M2Tech still uses proprietary drivers, but if they do you will need to install them and then the HiFace should appear as an option in the output selection fields in JRiver.
Mike B.
Re: JRiver
« Reply #4 on: 27 Jan 2017, 05:01 pm »
I recently purchased a similar unit from another source. I had to download their driver from Windows. I also had to go into the audio options in jriver and switch to their listed output . It is my understanding Co-ax will only do 24/192 max?
groovy.guru
Re: JRiver
« Reply #5 on: 27 Jan 2017, 05:48 pm »
As the others have said, the answer is yes.
Go to Tools > Options > Audio Device.
Derockster
Re: JRiver
« Reply #6 on: 28 Jan 2017, 12:58 pm »
good morning All,
Thank you very much for your assistance.
As a result I have got my JRiver installed and setup.
Regards
Derockster
