Pioneer Elite bdp-09fd CD/Blu Ray Player reduced
0 Members and 1 Guest are viewing this topic. Read 1504 times.
mikeg1
« on: 22 Jan 2017, 12:51 pm »
Original owner, box and manual, three years old, and mint condition.  This was the Pioneer flagship blu-Ray player.  Used mainly for blu-ray movies.  Laser pick-up was replaced recently by Pioneer so this should last a long time.  CD play back is very good. Was $2200 new.  $449 shipped from 66085. See 100% audiogon feedback under mikeg.  Eight Wolfson DACs to provide excellent two channel performance and three video chips provide reference video performance.
http://www.pioneerelectronics.com/PUSA/Home/Blu-ray-Disc-and-DVD/Elite-Blu-ray-Disc-Players/BDP-09FD
Performance Features
HDMI® 1.3a Output
Dolby®TrueHD and DTS-HD®Bit-stream Out
48-Bit Deep Color Support
X.V.-Color
AVC-HD
1080p True 24FPS Video Output (BD/DVD)
Original Pioneer Developed 16-Bit Video Processing LSI
15 Different Video Adjustments
3 Different Noise Reduction Circuits
Internal Audio Decoders
Dolby TrueHD and Dolby Digital Plus
DTS-HD Master Audio via Firmware Update
DTS-HD High Resolution Audio via Firmware Update
7.1 Channel Analog Audio Outputs
BD-Live™ Ready* with 4GB of Internal Memory
Coaxial Frequency Response Improvement
PQLS Jitter Free Audio Transmission
*Some initial production BDP-09FD players may require a firmware update.
Convenience Features
Advanced Bit Rate Meters
Advanced Playback and Search Modes
Dual HDMI® Outputs
Locking Component Video Connectors
RS-232C Control for Custom Installation
Audio Features
Dedicated Analog Audio Power Supply
A dedicated power supply for the analog audio board ensures top quality sound by eliminating unwanted interference caused by a shared power supply.
Custom made capacitors were used to deliver superior performance not possible with off the shelf components.
Toroidal Transformer providing limited stray magnetic fields and high electrical efficiencies. This results in superior audio reproduction due to lower amounts of electrical noise.
8 Wolfson Audio DACS running in Dual mode providing superior signal-to-noise ratio (120db) and uncompromised transparency with the source.
Audiophile Construction
Body Construction
Aluminum›Panel (Front/Top/Side)
Steel Cross Bar Supports
Double Layer Top Panel
Solid Steel Bottom Plate
Low Center Load Drive
TAOC Insulator Feet
Three Chamber Construction
Internal Construction
Separate Analog Audio BoardSeparate Analog Power Supply
Separate Digital Power Supply
Separate Video Board
Pioneer Developed Parts
Terminals
HDMI 1.3a Output (x2 Main and Sub)
Component Video Output*
Composite Video Output*
S-Video Output*
7.1-Channel Audio Output*
2-Channel Audio Output
Coaxial Digital Output
Optical Digital Output
Control In
RS-232C Control
*Gold Plated
Specifications
Power Requirements: 120V/60Hz
Product Weight: 30.42 lbs.
Product Dimensions
W x H x D: 16.54” x 5.63” x 14.17”
« Last Edit: 12 Mar 2017, 11:13 am by mikeg1 »
mikeg1
Re: Pioneer Elite bdp-09fd CD/Blu Ray Player reduced
« Reply #1 on: 19 Mar 2017, 11:33 am »
Bump
