0 Members and 1 Guest are viewing this topic. Read 3055 times.
Thanks guys, is there enough wiggle room so to speak to re-tap the hole while it's in place on the speaker? Or would I need to detach it from the cc3 and then tap it? This would do the trick, yes? The set screws for the Maggies are 8-32...looks like this has that size tap (?)https://www.amazon.com/Klein-Tools-625-24-Triple-Tap-10-24/dp/B0002RI788/ref=sr_1_1?ie=UTF8&qid=1485063345&sr=8-1&keywords=tap+tool+8-32UPDATE: Disregard the wiggle room question...I see that the connections panel on the back of the CC3 just unscrews and comes right off very easily...so the tap tool should work...right? PS. Mild tangent here, but do you guys have any experience with replacing the fuses on your maggies? I have heard people doing that over the years, but I never took the time to look into it. I saw this list the other day and thought Id check with you guys... https://www.thecableco.com/newsletter-detail.aspx?iid=5924
