Crossing open baffle bass and a bookshelf speaker
0 Members and 1 Guest are viewing this topic. Read 1994 times.
mirekti
« on: 21 Jan 2017, 04:49 am »
I have sealed box bookshelf speakers which I'd like to augment with open baffle bass, crossed @75Hz.
When listenig to the music I pull the speakers into the room for near field listening and that is fine.
However, when I watch TV the speakers are some 2ft from the wall behind them. As open baffle speakers need to be away from the back wall I wondered what I could expect will happen with bass? Will it totally mess up the sound?
nicoch
Re: Crossing open baffle bass and a bookshelf speaker
« Reply #1 on: 1 Feb 2017, 05:22 pm »
you loose some bass no problem for tv....
Poultrygeist
« Reply #2 on: 23 Feb 2017, 11:27 am »
Before going all OB I enjoyed this set up with the H-frame Alphas. For good OB bass they need to be pulled out into the room. If you build H-frames you can place them on castors or put furniture sliders underneath.
AJinFLA
  • Soundfield Audio Loudspeakers
    • Soundfield Audio
« Reply #3 on: 23 Feb 2017, 03:27 pm »
No. The >3' rule relates to spatial rendition, so it's critical for around 600-700hz on up.
For <75hz, you'll be fine @ 2'. If it's a flat baffle, you can rotate (toe-in) a bit as well.
