Tube, Hybrid, or SS Pre?
0 Members and 1 Guest are viewing this topic. Read 1578 times.
RPFMusicman
« on: 17 Jan 2017, 02:33 pm »
Looking to upgrade my existing pre (Auralic Taurus Mk II) very versatile product for what it is. Need a pre to match up w/ Simaudio W-3 poweramp.
Re: Tube, Hybrid, or SS Pre?
« Reply #1 on: 17 Jan 2017, 02:50 pm »
Welcome RPFMusicman :thumb:
I would suggest a tube pre.
mresseguie
« Reply #2 on: 17 Jan 2017, 04:05 pm »
Hi, Musicman.
FRM and I are biased the same way, so I'd recommend a tube pre as well. Of course, randomly select 10 audiophiles and you might end up with 4 who say, "tubes", 4 who say, "solid state", and 2 who say, "Forget the preamp - use your DAC as a pre."
Actually, I want to ask questions before I answer a question like yours.
I always ask about budget. How much can you spend on a preamp?
New or Used?
Do you want one with a phono pre inside?
There are some amazingly well informed and experienced posters here. You may get a bunch of interesting ideas to pursue.
Enjoy!
Michael
JCS
« Reply #3 on: 17 Jan 2017, 04:10 pm »
Not sure just what you are after, but you might take a look at:
http://schiit.com/products/freya
I have their Saga & like it very much.  Of course, you would want to think about tube rolling.  My Saga came w/ what I think is a cheap Russian 6N8S tube; replace w/ NOS RCA or whatever.
Cheers,  Jim
OzarkTom
« Reply #4 on: 17 Jan 2017, 04:11 pm »
+1
Chris Adams
« Reply #5 on: 17 Jan 2017, 04:19 pm »
The Simaudio W-3 is billed as a neutral sounding amp. This is good as it will show off the character of what's in front of it. I also recommend a tube pre with this amp. The question is which one because they can sound from tubey warm to SS cool. Tubes are a dark hole to go down :icon_twisted: and I have gone from all SS to all tubes and find myself listening longer and enjoying the time spent more.
« Reply #6 on: 17 Jan 2017, 04:30 pm »
After 20 years on the game I only rec tubes for preamps.
Phil A
« Reply #7 on: 17 Jan 2017, 04:39 pm »
Welcome - I have two systems with tube preamps and solid state amps
RPFMusicman
« Reply #8 on: 17 Jan 2017, 05:06 pm »
Thank you to all for the responses. Looks like a balanced tube pre is in order.
Looking at a pre-owned Octave as an option
