0 Members and 1 Guest are viewing this topic. Read 7667 times.
The crossovers are huge and use very high quality parts but I'm afraid they weren't changed for the BG's - there's no notch filter - which is very audible. They're definitely going to need some work. I think a Behringer DCX2496 is in my future.
They came with a Marchand XM144-1 one way (low pass @244Hz crossover) for the woofers. Good news is that all the drivers work great, the bad news is that they sound pretty awful, with very peaky mids. I ordered a DCX2496 so I'm sure I'll get them sounding right soon.
A few things seem a little odd though. There is no low pass or notch filter on the BG, and no bleed resistors for the much more sensitive Arcum Cantus tweeters. I have lots of amps to play with so I'm sure I'll be able to flatten them out with my new 2496. I'm guessing these were a DIY upgrade by the previous owner, there's no way Brian would be happy with the way these sound.
Hey Stimpy, thanks for the pics. That's exactly what these were. Do you own those original FF1's? I wonder if they have the same super simple crossover as mine, just two compound caps and two coils.
For now I'm using them for subs electronically crossed over at 50 Hz while I wait for the Behringer to arrive. They make incredible subwoofers, especially combined with my JBL 2245 infinite baffle sub.
I got curious and carefully peeled off the foam from the front baffle. Twin tweets (why 2?) look to be Aurum Cantus G3's although the labels have been removed. The front baffle, which was of course modified when the update was done, is incredible. They look like solid oak lined with two layers of 2/3" MDF. No wonder they were so hard to get into place!
There is no third woofer or passive radiator on the bottom, that hole has been plugged too.
