SOLD!!! Swagman Labs 9V/2A Audiophile Linear Power Supply
0 Members and 1 Guest are viewing this topic. Read 2583 times.
groovybassist
SOLD!!!
Ships from 27519. You can check out my feedback under same moniker at A'gon, so you're assured an easy transaction.  Paypal accepted.
Swagman Labs Linear PSU - this is the "audiophile" version, not the standard and includes upgraded Talema toroid.  9V/2A - perfect for powering the Uptone Audio Regen or similar devices.  $130
« Last Edit: 9 Feb 2017, 12:29 am by groovybassist »
mooncrikit
Re: FS: Swagman Labs 9V/2A Audiophile Linear Power Supply
« Reply #1 on: 15 Jan 2017, 05:49 pm »
What is the msrp on this unit? Thanx, Jeff
groovybassist
« Reply #2 on: 15 Jan 2017, 07:52 pm »
Jeff:
It was $225 new - I'm the original owner, receiving it directly from Swagman. The pics show some light reflections, not wear and tear. It's basically in the exact condition I received it - no issues, just don't need it any more.
-Mike
mooncrikit
« Reply #3 on: 15 Jan 2017, 09:44 pm »
Thanx Mike for the clarification. Sadly, this unit will not work with the microrendu I am trying to acquire. It is rated  for 7 volts up to 9 volts but at only one amp..and I quote from the Sonore website...
"The Sonore microRendu utilizes an optional power supply capable of delivering 6-9 volts at 1 amp min (center +). Do not exceed these power specifications or damage to the unit will occur. Damage from an unapproved power supplies will void the unit's warranty. "
Regardless, I trust you will easily sell this unit as it is a really nice option...
groovybassist
« Reply #4 on: 15 Jan 2017, 11:30 pm »
Jeff:
You're actually fine with a higher amperage rating - just means the LPSU can supply more current than is needed for the microrendu.  What you definitely want to avoid is a higher voltage rating than the microrendu is spec'd for - this will overheat the microrendu, shortening it's life at a minimum.
You're welcome to check in with the folks at Sonore, but I think they'll say this LPSU at 9v/2A is fine.  Good luck whichever direction you end up going.
-Mike
GregC
« Reply #5 on: 29 Jan 2017, 04:08 am »
I have a 12V and 15V standard edition PSU from Swagman he builds quality stuff.
