SOLD - Quicksilver Audio Line Preamplifier
0 Members and 1 Guest are viewing this topic. Read 1992 times.
mike_p
  • You Never Blow Your Trip Forever
« on: 11 Jan 2017, 01:59 am »
2010 production tube linestage, in VG condition. 4 inputs, tape in/out and main out. This model has the stereo/mono switch, which I found helpful and convenient. Balanced and effortless sound. Capable of reproducing a deep, wide soundstage, extending wall-to-wall on the right recordings in my listening room.
$550 plus actual shipping. No PP fees.
From Quicksilver's write-up:
"Completely redesigned for 2010, the new Quicksilver Linestage Preamp features wider bandwidth, increased dynamic range and lower noise. More power supply capacitance, a newly designed audio choke, and silver wire combine to provide a clearer more powerful presentation within a wider and deeper sound stage. The simplicity and solid construction of the original Linestage have been retained.
Since 1981 Mike Sanders has been producing well made, dependable and great sounding tube electronics. In a word, Quicksilver products epitomize the term value.
The company’s designs are simple, reliable and well executed. Even though Quicksilver products are reasonably priced, Mr. Sanders believes in the value of meticulous hand-built construction techniques. The quality of each and every part of the design is chosen with the intended task in mind, and is selected for its sonic contribution to the goal.
You won’t see advertisements for Quicksilver products in audio magazines. Mike believes that if you offer a quality product, reputation will spread by word of mouth. This cost savings allows Quicksilver to use top quality parts, and labor intensive hand construction, while keeping their prices low.
We think you’ll find Quicksilver designs to offer a unique blend of sonic strengths, excellent reliability and superb value.
The Quicksilver Line Stage Preamp embodies the Quicksilver philosophy of simplicity. It uses only one 12AX7 per channel, resulting in a very direct sound. A precision Alps attenuator, with 41 detents, is used for the volume control. The gold-plated Teflon insert RCA jacks are chassis mounted for long life.
Quicksilver products are handcrafted in the U.S.A.
• Two 12AX7 tubes • Gain is 18 dB (low gain 12dB unit available on request) • 100k Ohm input impedance • 100 Ohms output impedance • Minimum load is 20k Ohms • 3"H x 9 1/2" x 15"W • Weight 12 pounds"
« Last Edit: 13 Jan 2017, 12:28 am by mike_p »
Big Red Machine
Re: Quicksilver Audio Line Preamplifier
« Reply #1 on: 11 Jan 2017, 11:51 am »
Anybody starting out or wanting to jump up to separates should look at this unit hard.
