$0LD: FURUTECH FLOW 28 IN-LINE POWER FILTER
0 Members and 1 Guest are viewing this topic. Read 816 times.
mooncrikit
« on: 9 Jan 2017, 03:17 pm »
$0LD....The Flow-28 is a sophisticated, luxuriously made and finished inline power filtering unit that eliminates many common problems caused by contaminated electrical power lines. It protects against distortion caused by ground noise, voltage spikes and sags, high frequency power supply noise from other components in your own system, plus high frequency digital noise from processors and digital interconnects. You’re never alone when you take your seat; the residential AC supply is shared with other apartments, homes, and businesses on the same utility transformer explaining why many enthusiasts notice their systems perform to a higher standard late at night and weekends. The Flow-28 features the FI-28R IEC connector. And it incorporates the AC-1501R EMI-filtering IEC Inlet. The Flow-28 Inline AC Filter lowers noise on every component on which it’s used resulting in very natural and extremely fine resolution down and through the utterly silent noise floor. It improves sound staging and image palpability and creates musical highs, an attractive, engaging midrange, tight and controlled bass, plus you’ll notice power and dynamics to spare. As I am the second owner, this item is basically in "as new" condition, hence the 9/10 rating...This is the real deal, not a Chinese knock off. Purchased from VH AUDIO this past April. Factory packaging & proof of original purchase will be included MSRP @ $540.99 Your price is now $0LD, more than 50% off! (plus fees & shipping)
« Last Edit: 6 Oct 2017, 01:47 pm by mooncrikit »
