FS: Red Wine Audio Signature 16
0 Members and 1 Guest are viewing this topic. Read 2154 times.
TomekZ
« on: 6 Jan 2017, 05:20 am »
For Sale: RED WINE AUDIO Signature 16 HPA. In Cherry woodboth dark heart wood and lighter new growth wood.
The amp has 3 inputs with a high/ low gain switch for more accurate channel balance tracking and dynamic bloom (note there is not a headphone mute switch...I mostly used efficient headphones and lower efficient speakers, but also used a multi-speaker switch which can be gotten at low cost on ebay etc.; or Vinnie Rossi will modify, so he told me). The headphone output is balanced and I will include cables, if desired, for HifiMan original screw on fitting early 400i or 560 etc and/or 2.5mm pin fitting Audioquest Nighthawk, Oppo, Sennheiser  HD700.  I've 3 meter lengths of each. )  The headphone amp, like the amp and DAC has a spectacularly black & quiet background for use with the most efficient headphones or speakers. The headphone section surpassed a few tube amps I've had, but not my current jazzed up microZOTL. The amp is 16 watts into 8 ohm, 32 into 4 ohm and reported to be powerful watts. It also is tonally adjustable and sweetened by a choice of 6dj8 or 12ax7 or many other tubes. See pic regarding in internal dip switch. I'll include 3 tubes
 for tube rolling enjoyment. The tube is part of the input on the amp which runs mosfets on the output.
Two remotes included, one the newer metal chassis and one an older plastic (from a previous component I had).
If you've any questions, I love to go into more detail.
The amp case is in Cherry wood. It is pictured stacked on top of a Bellina DAC...which I am not selling, unless begged.
ASKING $925
TomekZ
Re: FS: Red Wine Audio Signature 16
« Reply #1 on: 11 Jan 2017, 04:17 am »
 :D
« Last Edit: 17 Jan 2017, 03:30 pm by TomekZ »
tlarwa
« Reply #2 on: 12 Jan 2017, 02:22 am »
I owned the Signature 30 integrated for a while, and it was excellent.  I would recommend this to anyone with efficient speakers.  Great amp.
roscoe65
« Reply #3 on: 6 Apr 2017, 01:42 am »
Is this still for sale?
