Harmon Kardon Citation 7.1 THX certified 4/3/2 ch amp.
0 Members and 1 Guest are viewing this topic. Read 1521 times.
jriggy
Cleaning out the closets!
SOLD
I have a Harman Kardon Citation 7.1 Amp for sale.
This amp is powerful and bullet proof.
Check out all the great user reviews here:
http://www.audioreview.com/mfr/citation/amplifiers/7-1/PRD_115649_1583crx.aspx
22 Reviews
4.95 of 5
High current, multi-channel amplifier, configurable for four, three or two-channel output.
THX CERTIFIED
Power Output
4 x 150 watts @ 8 Ohms,
4 x 240 watts@ 4 Ohms
2 x 150 watts + 1 x 450 watts @ 8 Ohms
2 x 450 watts @ 8 Ohms bridged
FTC: 20 Hz - 20 kHz, .03% THD, All channels driven
HCC 130 Amps/channel in dual mono mode
Frequency Response < 3 Hz - 200 kHz ?3 dB at rated output
THD/IMD Less than 0.03% at rated output
Power Bandwidth 5 Hz - 130 kHz
Input Impedance 22k Ohms
Input Sensitivity 1.1 volts for rated output
Dimensions (HxWxD) 7 1/2 x 17 15/16 x 17 1/2"
191 x 456 x 445 mm
Weight 75 lbs / 34 kg
Power Requirements 120/230VAC, 50 - 60 Hz; 2500 watts, maximum
Its in great shape. pics upon request, if needed but Ill probably take some once I get it down from the shelf and ready for its box.
$460.00 or best offer, plus shipping from 46220
Ill dig out the box to check exact size and wight...
Any questions? Feel free to PM me.
Thanks for looking
 Jason
« Last Edit: 13 Jan 2017, 10:29 pm by jriggy »
zapper7
  • Its time to have fun, its fun to have time
Re: Harmon Kardon Citation 7.1 THX certified 4/3/2 ch amp.
« Reply #1 on: 3 Jan 2017, 08:36 pm »
You have a PM
