4BSST2 VS 4B3
0 Members and 1 Guest are viewing this topic. Read 5699 times.
AG
4BSST2 VS 4B3
« on: 1 Jan 2017, 11:41 am »
Hi folks :)
I would like to know what differences you experience when comparing the two amplifiers. What are the main, well noticeable differences between the sound of the two amplifiers regarding the sound stage, warmth, dynamics, extreme frequencies, accuracy, linearity. Is it worth it to upgrade?
CanadianMaestro
Re: 4BSST2 VS 4B3
« Reply #1 on: 1 Jan 2017, 03:31 pm »
Hi folks :)
Can you audition them?
So much depends on other factors....room acoustics, sources, speakers, even cabling.
AG
Re: 4BSST2 VS 4B3
« Reply #2 on: 1 Jan 2017, 04:26 pm »
Unfortunately I cannot. But I know the 4bsst2 as I owned it for 3 years.
Let's assume you are using the same cables,room,etc...
Dloines
Re: 4BSST2 VS 4B3
« Reply #3 on: 2 Jan 2017, 02:52 pm »
check out my post on the same subject:  http://www.audiocircle.com/index.php?topic=147325.0
AG
Re: 4BSST2 VS 4B3
« Reply #4 on: 2 Jan 2017, 03:07 pm »
Thanks,that is a good sum-up.
Anybody else?
