New to Clearaudio. Have a few questions about set up and maintenance.
0 Members and 1 Guest are viewing this topic. Read 1672 times.
jancanderson
Hello all,
Longtime lurker, first time poster. I've done some pretty thorough digging and have struck out trying to find any threads that completely answer my questions, so I'm starting a new one.
I recently purchased a secondhand Clearaudio concept. The sale came with a MM concept cartridge (used; mounted), a Clearaudio dustcover, and a nano phono v1. I've been looking to upgrade my table for months, and when this came up at a great price I jumped on it without hesitation. A few hours after closing the deal I'm starting to realize that there are some downsides to buying this table secondhand, namely the lack of customer support I'd get through an authorized dealer. In order to save $$ off the sticker price, it's time I learned to be a self sufficient audiophile. My primary question to any concept owners is this: What servicing should I expect to perform on this turntable and what tools and/or materials will I need to set up the table?
The table itself looks to be in good condition. I purchased it through an online sale on a legitimate site, but the description was lacking and the pictures could have been more thorough. Basically all I know is that this is a one owner unit and was purchased from Acoustic Sounds. It's three years old, and I'm guessing it hasn't been recalibrated, oiled, had a belt changed, or had the cartridge replaced in all that time. From what I gather, based on the item description in the listing and what the owner has told me in DMs, the unit is a few years old, was used moderately, and while it was never abused, it certainly wasn't meticulously maintained.
The table happens to be about a two hour drive from me, so I'm thinking I'll go pick it up in person instead of risking shipping (seller didn't save the packing materials). Once I get it back to my home, I'll be on my own setting it up and servicing it. I live in a midsized city without a good audio shop, and the closest Clearaudio dealer is two hours away. Are there any resources that any concept owners would recommend reading/watching? Are there any tools I should go ahead and order? (I assume that nothing is coming with the sale except the items listed.) Any pointers some more experienced hands would give a Clearaudio noob?
Thanks in advance for all of your help. I'm a bit out of my depths but feel confident in my abilities. Just to give you a sense of my technical proficiency, I've been into collecting LPs for 10+ years and have owned a half dozen turntables, but this will be my first foray into higher-end gear.
richidoo
I have an early version of this table, with small metal spike feet. Bought used on AC with Maestro Wood cart. Not much maintenance needed on this table. The power input jack fell apart in my hand the first time i tried to plug in the power plug. I removed the bits of the original jack and soldered on a nice Switchcraft barrel jack to the wires. Check the jack on your TT.
My friend bacobits (not sure his current username, but he's active here on AC) gave me some good advice on setting up Clearaudio TT. He has higher model, but he knows his Clearaudio stuff. I had medium success before his advice, then with his help it clicked and the sound has been great since. Thanks Den!
Adjusting VTA is important, as it is on all tables. I use an index card with lines to make the arm level, then adjust VTA to taste from there. It's a crude adjustment, so you have to just do your best. I can't remember exactly where it ended up, but different carts will be a little different anyway. Listen to find the best height.
I forget what I did for alignment, but I think I borrowed an alignment jig from Pumpkinman and found that the cart was already aligned perfectly by the AC seller or the original dealer. That's about it. It's simple and high quality table for the price, the arm is very good. I like German stuff. I have no desire to upgrade. Vinyl isn't my main source, but I do have about 500 old jazz sides, but only a couple audiophile pressings. They sound really good. Anand has brought over some nice audiphile pressings and his tube phono preamp, wowsa. The TT is no slacker given the opportunity to shine.  Good luck on your purchase.
Rich
bacobits1
Hi guys,
Yes I'm not about to change anything here either.
I have for 3 years now the CA Emotion SE CMB/ Carbon Satisfy arm table and it sings. I'd put it up against much more $$ offerings out there. I also use a Falcon Power Supply.
What advice I gave Rich was the correct Alignment Arc protractor for these tables. Contact me if interested.
The index card is good easy advice for leveling the arm. A good digital scale (non magnetic) is also necessary. Just make sure the bearing is cleaned/ oiled, belts last a long time mine has not been replaced, they run like $50.
Quite low maintenance after initial cartridge set up.
D
lennie trystero
I switched to a Concept after years of struggling with vintage turntables (mostly Thorens), and while I loved the tinkering, it's nice to have something that just works. I installed my own cart (a Shelter 501 mk ii I had on hand) but otherwise the TT has required absolutely no maintenance until today, when my new belt arrived -- I'm going to replace it in a moment.
It's good advice about VTA though - it can be fun to try out very small differences to see how they can make very small (or sometimes not-so-small) differences in sound. But mostly you'll just be able to enjoy it. The magnetic arm bearing and delrin platter are outstanding.
bacobits1
If you are level on vta you are more than likely good. More important is the overhang alignment which is measured via the arc protractor. That is where you will hear the differences as everything comes into focus.
