VMPS - 626R Spiral Tweeter
0 Members and 1 Guest are viewing this topic. Read 2036 times.
Shear Bliss VMPS
« on: 31 Dec 2016, 12:30 am »
It seems I have a Spiral Tweeter out ..... looking for one or perhaps a pair to get my 626Rs back up, anybody have extras ???
Thanks, DW
Evoke
    • EVOKE Planar Loudspeakers
Re: VMPS - 626R Spiral Tweeter
« Reply #1 on: 31 Dec 2016, 01:20 am »
Go to the VMPS page and contact John Casler. He worked directly with Brian and may know of tweeters available - Buy 2 and change both.
Stimpy
« Reply #2 on: 31 Dec 2016, 06:18 pm »
I believe the Infinity EMIT-R was close, if not identical, to the tweeters Brian used in the base model 626R.  If so, those are easily found on eBay.  This seller even has new units for sale (none mine):
http://www.ebay.com/itm/Ribbon-Tweeter-for-Infinity-Emit-902-5754-Kappa-5-1-6-1-7-1-Speaker-MT-6769-/161675156708?hash=item25a4971ce4:g:rg8AAOSweW5VMCia
If the impedance matches what you're replacing, it should work fine.
Good luck!
Evoke
« Reply #3 on: 31 Dec 2016, 06:45 pm »
Good luck!
ATD was the original supplier. Infinity used them back in the day too. Both ATD distributors listed are out of business. You may search EBAY for them. It’s the RDT-25. There are a number of tweeters that are good drop-ins. Check Madisound - they have a great selection. Also, Genesis speakers uses a new iteration of the RDT-25 which makes sense in that Arnie Nudell of Infinity now designs their speakers. The BG Neo3 series with a round faceplate would also be good replacements. Visit Parts Express for them. As Brian said - price/performance is the key and the BG sounds MANY times its cost.
Shear Bliss VMPS
« Reply #4 on: 1 Jan 2017, 12:30 am »
Yes John contacted me and he has some, will do both spirals. Checks in the mail Monday John, thanks again!!
DW
