SOLD. Gallo Reference 3 SA Amplifier
0 Members and 1 Guest are viewing this topic. Read 807 times.
kebhuh
« on: 29 Dec 2016, 12:31 am »
Gallo amp, designed for 2nd voice coil/woofers on Gallo's Ref. 3.0 speaker but suitable for other apps. Specs below.
Price: $475 plus ship from SE CT.
Thanks ...
2 x 160 watts RMS @ 8 ohms
20Hz - 20kHz (stereo mode)
2 x 250 watts RMS @ 4 ohms
450 watts RMS @ 8 ohms
20Hz - 20kHz (mono mode)
650 watts RMS @ 4 ohms
Distortion:    0.08% stereo, 0.1% mono
(low-pass @ 100Hz, level and xover at max, EQ at 0dB)
.01% stereo, 0.17% mono
(full-range, level at max)
Input Sensitivity:    130mV stereo, 110mV mono
Signal-to-Noise:    93dB stereo, 83dB mono
(low pass @ 100Hz, level and xover at max, EQ at 0dB)
93 dB stereo, 75dB mono
(full-range full-rated power @ 1kHz)
Load Impedance:    2 ohms or greater in stereo mode /
4 ohms or greater in mono mode
Bass EQ:    1W @ 35Hz (100Hz=0dB, level and xover at max, booster at 6dB)=6.2dB
1W @ 35Hz (100Hz=0dB, level and xover at max, booster at -3dB)=-3.2dB
Frequency Response:    15-200Hz low-pass (100Hz=0dB, level and xover at max, booster at 0dB)
<10Hz - 28kHz full-range (100Hz=0dB, level and xover at max, booster at 0dB)
Crossover:    40Hz low-pass, xover setting at minimum
200Hz low-pass, xover setting at maximum
Power Handling:    250 watts @ 4 ohms
160watts @ 8 ohms (In Stereo)
650 watts @ 4 ohms
450 watts @ 8 ohms (Bridged to mono)
12 Volt Trigger:    Tip = (+) Sleeve = (-)
Auto-on Sensitivity:    5mV
Current Draw:    9A stereo, 13.5A mono
(level and xover at max, booster at 0dB)
Protection Circuitry:    Short circuit, open circuit, RF burnout, over temp., speaker protection relays, Turn on/off transient protection, DC protection, and limiter circuitry
Temp. Protect:    60°C +/-5
Cooling:    A low noise fan is utilized to draw cool air through the chassis using front and rear vents. Do not block the vents.
Power Requirements:    100 VAC 60Hz, 850VA
100-120 VAC 50/60Hz, 850VA
220-240 VAC 50/60Hz, 850VA
Dimensions:    19"W x 3.81"H x 15.62"D
Weight:    35 lbs
Connections:    RCA inputs, 5-way binding posts
« Last Edit: 23 Feb 2017, 01:56 am by kebhuh »
