BDP-1 vs BDP-2
0 Members and 1 Guest are viewing this topic. Read 4840 times.
matthewpartrick
  • vinnierossiforum.com
    • The Clueless Audiophile
BDP-1 vs BDP-2
« on: 28 Dec 2016, 02:35 pm »
I've been having a lot of problems with my main Roon endpoint lately and have been thinking of upgrading, and Bryston is high on my list.   I've found a NOS BDP1 for an attractive price, but am wondering what are the main differences between the BDP1 and BDP2 and if it's personally worth it to me to upgrade?
Thanks in advance.
CanadianMaestro
Re: BDP-1 vs BDP-2
« Reply #1 on: 28 Dec 2016, 03:33 pm »
Larger library capacity and faster load times are the biggest differences.
zoom25
Re: BDP-1 vs BDP-2
« Reply #2 on: 28 Dec 2016, 04:47 pm »
I don't think so. He mentioned he found a NOS BDP-1. The NOS should put it over the top, literally.
http://www.etonline.com/movies/2015/04/24142435/GIF_2_fast_2_furious_nitro_jump.gif
CanadianMaestro
Re: BDP-1 vs BDP-2
« Reply #3 on: 28 Dec 2016, 08:25 pm »
His question was what were the diffs between BDP-1 and -2. Not between NOS -1 and -2. I am going by what he wrote in his OP.
AG
Re: BDP-1 vs BDP-2
« Reply #4 on: 2 Jan 2017, 01:41 pm »
If you don't want to play files from the optional internal hard drive and your budget is tight  the bdp-1 is fine.
Sonically they are the same.
I want to play all my music files from the internal 1TB SSD so I went for the bdp-2
In my opinion this set up is the most trouble free,independent and gives me the highest possible sound quality
I wish Chris gave the copy-paste ability from a USB stick to the internal SSD as it is possible with my cheap Dune media player
« Last Edit: 4 Jan 2017, 04:28 pm by AG »
schmidtmike76
Re: BDP-1 vs BDP-2
« Reply #5 on: 2 Jan 2017, 03:20 pm »
Sound advantage would be the ability to use AES.
zoom25
Re: BDP-1 vs BDP-2
« Reply #6 on: 2 Jan 2017, 03:35 pm »
Both BDP-1 and BDP-2 have AES.
schmidtmike76
Re: BDP-1 vs BDP-2
« Reply #7 on: 2 Jan 2017, 09:50 pm »
I stand corrected
matthewpartrick
Re: BDP-1 vs BDP-2
« Reply #8 on: 4 Jan 2017, 04:31 am »
Can the BDP-1 play files on an NAS attached to the Ethernet plug?
Dave Jameson
Re: BDP-1 vs BDP-2
« Reply #9 on: 5 Jan 2017, 05:21 pm »
Yep. Makes for a nice Roon Ready endpoint too! The only limitation is that the BDP1 is a bit slow to boot up and it's designed for relatively small libraries.
ttsto
Re: BDP-1 vs BDP-2
« Reply #10 on: 5 Jan 2017, 06:38 pm »
Do you mean a direct patch from BDP to NAS or BDP to router to NAS? If first case, I don't think so...
matthewpartrick
Re: BDP-1 vs BDP-2
« Reply #11 on: 11 Jan 2017, 02:21 am »
I might be leaning towards the BDP2 in an attempt to prevent automatic obsolescence.  Will keep you all posted.
CanadianMaestro
Re: BDP-1 vs BDP-2
« Reply #12 on: 11 Jan 2017, 11:38 am »
What do you mean by "automatic obsolescence"?
unincognito
    • bryston.com
Re: BDP-1 vs BDP-2
« Reply #13 on: 11 Jan 2017, 04:08 pm »
I'm not sure what he means by that term, but the BDP-1 is a 32bit platform and eventually we will need to switch to a 64bit kernel which is the plan for Nutty Narwhal.
Chris
Marius
Re: BDP-1 vs BDP-2
« Reply #14 on: 13 Jan 2017, 09:05 pm »
Hi Chris,
Is this a hidden announcement for a BDP-3?
other enhancements might be in order, even the BDP2 won't be able to handle soon either?
Marius
Chris
unincognito
    • bryston.com
Re: BDP-1 vs BDP-2
« Reply #15 on: 13 Jan 2017, 09:50 pm »
Although the BDP-2 uses a 32bit chipset it has the capability of executing 64bit code
