HifiMan 560
0 Members and 1 Guest are viewing this topic. Read 1274 times.
Escott1377
HifiMan 560
« on: 22 Dec 2016, 04:16 pm »
Has anyone made their own aftermarket cable for this product?
I ordered a pair this week and will need a longer cable than supplied, and prefer to upgrade to OCC copper or silver.
If so, where did you source your connectors to the headphones?
Thanks in advance.
Re: HifiMan 560
« Reply #1 on: 22 Dec 2016, 04:18 pm »
HifiMan site can provide connectors and even do the cable for you.
They have made two cables for me, factory class products.
JohnR
Re: HifiMan 560
« Reply #2 on: 25 Mar 2017, 03:13 pm »
The earlier ones used a different connector to the current ones. Mine are the earlier ones and I just gave in after having two cables break at the connector and bought a pair of Adapters to 4-pin mini XLRs. Those you can make on your own cable easily.
milford3
Re: HifiMan 560
« Reply #3 on: 25 Mar 2017, 03:22 pm »
Moon audio is a great place for cables.  I have the Blue Dragon cable for my Audeze LCD2's
https://www.moon-audio.com/audio-cables/headphones.html
