0 Members and 1 Guest are viewing this topic. Read 1055 times.
veloceleste
« on: 17 Dec 2016, 07:28 pm »
« Last Edit: 22 Aug 2023, 08:10 pm by veloceleste »
  • The Demo is Everything!
    • http://www.bryston.com
Re: B60SST amplifier input sensitivity
« Reply #1 on: 17 Dec 2016, 09:36 pm »
Hi James,
Is the B60SST C series amplifier input sensitivity the same as other SST amplifiers? I'm considering horizontally bi-amping Mini T's with the B60 on top and Powerpac 120SST's on the woofers. I would split the preamp output. If not, I would drive the Mini T's with just the powerpacs.  I've searched and never found a reference to the B60 used this way, that's why I'm asking. Thanks.
Yes the sensitivity and gain is the same -- 29dB with 1 volt in.
james
veloceleste
sensitivity
« Reply #2 on: 18 Dec 2016, 11:06 pm »
« Last Edit: 22 Aug 2023, 08:12 pm by veloceleste »
